I ve been looking for a loader for the new-to-me JD 2030a nice 1973 with shuttle shift 8sp, foot throttle, double stack of rear wheel weights, fuel solenoid (stops with key) and a brand new ROPS/canopy. It has fittings on the hyd proportioning valve and filter housing that would power the loader without giving up my rear remotes. I haul from where we hay to where we live/raise livestock, so this is my ticket to going to small rounds (i.e., loader tractor on both ends.my other one is a Ford 3930 4WD with 7310 loader).
I have a chance to pick up a loader off a parts JD 300 for $500. The tractor itself is a sad storysomeone stole the 3ph assembly right off the top of the transmission! Any rate, it s a couple hours away and I need to uninstall it for this price. It s whole, needing some very doable bucket repair, rubber lines and one has to figure one or more cylinders/bushings/etc will have issues. I do like that it s a beefy loader carried on the rear axle, even if it s not a quick detach like my Ford.
I know the 300 is an industrial 1020, which is a 3cyl to my 4, and I have a longer wheelbase.TractorData.com says it has a "7300" loader, which the rest of the internet seems oblivious to. It looks like it will fit in terms of the front and rear brackets bolting up to my machine, but width and length of the main crossmembers would be impractical to change so it has to match. I haven t measured yetI can arrange that with some effort but thought I d just askAnyone know if it ll work?? If not, what loader models am I looking for?
