I need help diagnosing a problem with my 1950 Super C tractor engine. It appears that the cam shaft is no longer turning in sync with the crank shaft. When I turn over the engine with the starter, the valve push rods move some but then stop.
A few years ago the hydraulic pump froze and stripped the drive gear. Although the hydraulics was lost, the engine was, otherwise, running. The tractor was useless without hydraulics so it sat for a couple years. Recently I started the engine in order to move the tractor to a different location. It ran for 10 or 15 minutes but started running rough and quit. When I attempted to restart it backfired a couple times and then quit running. After checking gas and spark, I took off the valve cover and then learned the cam is not driving the push rods.
Is this repairable or is there likely damage to valves and/or pistons? How is the cam connected to the crank shaft? If it s repairable, what is the procedure?
