550Doug
- Location
- Southern Ontario
See attached photos
See the adjustment screw (RED) on each pressure plate finger, the UK made ones have a slotted screw, the USA ones may have a bolt with jamb nut.
Turn each adjustment screw 1/4 turn Clockwise, reason after many years of use the adjustment screw head wares a groove in the finger hole and by turning the screw 1/4 turn it positions the head of the screw out of the groove.
Afterwards make sure when the clutch pedal is at the top there is a gap between pressure plate and throw out bearing.
If no gap, re-adjust clutch pedal.
Also NEVER FORCE the PTO lever or you will shear off the roll pin on item #4 in the second photo
My pto will not engage with the tractor running. I have removed the inspection plate to view the clutch.
The above info was posted by JimB2 and I am trying to turn the above mentioned screws 1/4 turn, but no luck as there is either too much pressure on them or they are seized. Is there a way to get these screws to turn easily?
