Alaskannewfarmer
First of all, thanks for all the advice to this new tractor owner. I've helped in many bear hunting, salmon fishing, shooting forums and know some experts can be demeaning to new folks trying to enjoy my hobbies. I certainly have not expierenced this here. Thanks.
I have researched servicing my new to me 1974 IH 140. Unfortunately, either the IH required part numbers are obsolete or not avail in my area.
My manual says change oil with IH -low ash SAE 30, is this just 30 weight oil? HD or non-deterrgent? What do you use?
What spin on oil filter is the same as IH?
What plugs are a sub? are they still gapped at .30 as manual says?
What points are an obsolute IH replacement?
What hydraulic fluid for Trans and Touch Control reservior after draining by drain plug only?
Steering gear box lube? farmer told me to just put a full grease gun in but it dont sound right. What do you use?
Where should I buy an Allison 3 ribbed, tubed front tire to match one sides new one?
Both Fast Hitch Bail pins at attach points inside rear wheels have missing safety keeper pins. farmer told me to replace with nails. anyone know size or part number?
What antifreeze should I use and the mix ratio you use ?
All help is appreciated.
