Hi All,
I've been doing a lot of reading on here regarding swapping a Cummins 12 valve into an Oliver 1850, 1955, White 2-105 etc and think it sounds like a fun project.
I found a good running Cummins in a '93 Bluebird bus which is mated to an auto Allison AT545 transmission. Could a guy get rid of the old engine, bellhousing/clutch and the 3speed over/under and have space in there for the bus Cummins+AT545? The dimensions of the 545 are length 27", height 20.35" width 19.84". How big are the over under powershift units? If it did fit I was thinking to change gears on the standard tractor transmission with the AT545 in neutral and the AT545 could kinda do the job of the old clutch and over under trans? Would this work? Not sure how the 545 would be connected to the tractor transmission.
This idea was inspired by an old time that I saw put an engine and auto trans from a Nissan truck in a old farmall tractor and mated it to the original transmission. It seemd to work pretty good for him but he has passed on so i cant quiz him about it.
If this did work (physically fit in the space etc) would it be efficient? Pros and cons?
Thanks!
Thanks!
