Bolens/Iseki G194 fuel issue
BigMike26
My tractor sat for about 1-1/2 or 2 years. Had run, fine, but battery died, then had a rotten battery cable. I put in a new battery and new battery cables. I added fuel, it turns over, but won't start. I have checked fuel lines, etc...i have fuel all the way to the pump, but nothing out of the pump or injector lines. Is there something I am missing where I need to manually prime the pump? Thoughts?
Mike
This post was edited by BigMike26 on 07/22/2023 at 02:48 pm.
Start by following the bleeding procedure for that tractor. I once had one but don't remember the bleed process. But I think it involved the manual prime followe by loosening the injector lines one at a time and cranking the engine until fuel flows.
Thank you, for the replies. I will try
bleeding again, but I have about convinced
myself that the pump is not turning. I will
try to wrestle with that in the next week.
