JH Michigan
I have a 1966 Massey Ferguson 150 Perkins Diesel with multi-power it was my first tractor I bought and have owned for several years now. I am seeking advice from someone who has worked on the multipower transmission and has an idea how much it would cost to rebuild it. Right now the multipower shifts into high and low and the multipower seems to work but when shifting into high range you get hydraulic oil pumping out the weep hole. From some of the reading I have done it sounds like it’s a double split job and replacing the steel rings and the pto and main input shaft. My clutch is also starting to get weak and I believe the pto may be starting to slip under a heavy load. Any advice is appreciated as my mechanical ability is a beginner trying to learn as I go. Is there ever a time when the cost to repair is more than the tractors worth and is this one of them?
