Hello.
I am working on my father's old International 424d. It has not had a charging system for many years. It's just been kept on a charger and from time to time he'd leave the key on which would kill the battery.
Recently I added and led indicator for the key switch and a keyed relay so the lights (newly installed led all around) would require the key on to function. With the key off tractor running or not they turned off (before going to work on the charging system)
He had the generator rebuilt recently and I put a new voltage regulator on it.
I think the regulator is bad but would like some input.
Following the excellent info here:
No ammeter, just charge bulb which has been replaced and goes out after start. With the tractor running the led key switch indicator now stays lit and the keyed relay stays on even with the key off now which means it's now getting power from the generator through the dash wiring.
Tractor running
F terminal 5-6V
A terminal 13.50V
Batt terminal 12.06V (matches battery)
If I ground the F terminal
A terminal 12.25V
Batt terminal 12.25V
And both will gradually climb to 12.45V in a minute or two even if the ground is removed from the F terminal. I know the battery is low and the generator is going to max output which pulls it down. I haven't let it just run to see if it would charge up the battery.
It seems there's only output on the batt terminal with the F terminal grounded, and the A and Batt terminals match voltage even after the F terminal is ungrounded. Shut the tractor off and it goes back to battery voltage on the batt terminal and good 13.2 or higher voltage on the A terminal until the F terminal is grounded again.
So...bad VR?
Thank you.
VOLTAGE REGULATOR
Regulator, 12 volt. Flat mount, 3 terminals. For tractors with generators. Replaces Delco regulator 1119000, 1119000, 35A5137.
qualityfarmsupply.com
Farmall C charging system will not work
I have a !951 Farmall C that I can't get the charging system to work on. I have had the generator rebuilt and put it back on. I worked for a week trying to get the system to work. I finally gave up tooke the generator and the regulator to a shop that could check both. I did have a problem with...
forums.yesterdaystractors.com
Tractor running
F terminal 5-6V
A terminal 13.50V
A terminal 12.25V
So...bad VR?
Thank you.
